dsTNC / dsDigi
SP9UOB
Jméno: Tomek
dsTNC / dsDigi
Příspěvek od SP9UOB » pon 06. úno 2012 23:36:21
Hi,
First, Im sorry for english, but i dont know czech, and You would have lot of fun i'd be writing in polish ;-)
I want to share with You my project - TNC modem and APRS digi based on DSP processor:
http://sp9uob.verox.pl/dstnc.html
http://sp9uob.verox.pl/dsdigi.html
73! de SP9UOB
Re: dsTNC / dsDigi
Příspěvek od OK1ALX » úte 07. úno 2012 0:52:49
Hello, Interesting project.
What are the current digi-configuration capabilities? Such as settings for WIDE digi, or Fill-in digi, SSn-N, Dupe check time etc. :)
How does the digipeater handle the digipeating?
For example this packet:
OK1AAA to APRS via WIDE1-1 WIDE2-2
does it handle this way?
OK1AAA to APRS via OK0BBB-2 WIDE1* WIDE2-2
or this way?
OK1AAA to APRS via OK0BBB-2* WIDE2-2
Thank you for answer.
SP9UOB
Jméno: Tomek
Re: dsTNC / dsDigi
Příspěvek od SP9UOB » úte 07. úno 2012 21:09:36
OK1ALX píše:Hello, Interesting project.
Thanx.
Because lack of RAM memory (2 kb only, about 1 kb used in dsp algorithm) dsDIGI supports only WIDE1-1, no dupe checking is performed.
In dsDIGIv2 (much larger processor) will be full digi support with viscious delay and (maybe ethernet - Igate).
There is a filter function (circle, sector) - undocumented yet, still in testing.
OK1ALX píše: How does the digipeater handle the digipeating?
This way, but it can be configured by request. You may look to raw packets relayed by SR9NOH, SP3VSS-3 (early beta version), or SP9UOB-15
OK1ALX píše: or this way?
73! de SP9UOB,
Re: dsTNC / dsDigi
Příspěvek od OK1ALX » úte 07. úno 2012 21:29:15
thanks for details, looking forward to next version then :)
SP9UOB
Jméno: Tomek
Re: dsTNC / dsDigi
Příspěvek od SP9UOB » čtv 23. úno 2012 22:52:38
Hi,
New firmware is available:
- any alias WIDEn-N
- dupe checking
- telemetry (temperature, voltage, rx/tx count per 10 mins)
