Rfinder M1 DU DMR 4G/LTE (400-450MHZ)
ok1tec
Post by ok1tec »
Zdravim... Bude to chodit v CZ? Nebo je to dalsi kram na svete....
ZAjimava je jkonstrukce (sesroubovana), SMA antena, baterka na zasunuti, nabijeni na magneticky drzeny konektor...
The Rfinder M1 is all-in-one Transceiver (VHF or UHF) analogue and DMR Tier 2, with an embedded 4G/LTE Android smartphone. It’s point & click features make DMR operation as easy as ever.
h[url]ttp://rfinder.shop/product/rfinder-m1du/[/url]
Main Features 	LTE 4G, Android IP67 rugged smartphone, professional walkie talkie.
◇ Basic Info
◇ Release 	2017 April
◇ Walkie talkie output 	4W DMR; 4W FM 420-450MHZ or 440-480mhz
◇ Display 	4.7″ 1280*720 HD
◇ Touch Panel 	IPS capacitive scratch resistant touchscreen
◇ Glove wearing touch 	Support
◇ OS 	Android 6
◇ Platform 	MTK6735 Quad core
◇ CPU 	1.5Ghz
◇ Memory 	2GB RAM+16GB ROM
◇ Micro SD card 	Support up to 32GB
◇ SIM 	Support 1 SIM Cards
◇ Network 	FDD LTE/TD-LTE/TD_SCDMA/WCDMA/GSM
◇ Data connection 	GPRS,EDGE,HSPA,LTE CAT4
◇ Band 	2G: B2/B3/B5/B8;
3G:EVDO:BC0 WCDMA:B2/B3/B5/B8 TD-SCDMA:B34/B39
LTE-FDD: B1/B2/B3/B4/B5/B7/B8/B17/B20 LTE-TDD: B38/B39/B40/B41
US AT&T Only
◇ Date Rate 	LTE :CAT4 ( 150Mbps Downlink 50mbps Uplink)
WCDMA: Category 24 HSDA category 7 HSUPA
◇ Battery6 	200mAH Li-polymer
◇ Quick Charge Stand 	Support
◇ Colour 	Black or Green
◇ Size 	165mm*79mm*20.8mm
◇ Weight 	300g(handset) 350g(with battery)450g(whole package)
◇ Features
◇ PTT 	1st version: Analog(Standard)
2st version: Analog+DMR2(Optional),
◇ POC 	Push-to-Talk over Cellular/Wifi
◇ programmable key 	Support,Customer can customize the key for special function purpose by software
◇ IP Class 	IP67
◇ GNSS 	Support GPS/Glonass/Beidou/A-GPS
◇ Google map 	Yes
◇ IP Class 	IP67
◇ Sensor 	Gravity, Distance sensor, Light sensor, 3D accelerator, Gyroscope sensor
◇ Indicator led
* Red light 	press PTT key status
* Green light 	Walkie talkie receive signal status
* Blue light 	Long light: Walkit talkie switch on; Flash:missed call,SMS
◇ FM 	Yes
◇ NFC 	Yes,Frequency: 13.56MHZ(Optional)
◇ Cameras
◇ Camera 	Front camera:2 Mega pixels, Back camera:8 Mega pixels
◇ Sensor type 	CMOS
◇ Flash light 	Yes
◇ Video record 	Yes
◇ Video record resolution 	Support up to 1920*1080 pixels recording
◇ Others
◇ Video decoding 	MP4,3GP, WMV,AVI.
◇ Audio decoding 	WAV/MP3/MP2/AAC/AMR-NB/AMR-WB/MIDI etc.
◇ Ringtone 	WAV/MP3/MIDI
◇ Picture 	JPEG etc.
◇ Game 	Support
◇ Data
◇ WLAN 	802.11 a/b/g/n 2.4G/5.8G
◇ USB 	Micro USB 2.0
◇ Earphone Jack 	Pogo Pin port,
◇ Bluetooth 	BT4.0
