DV4mini nefunkcni
DV4mini nefunkcni
Post by ok1tec »
Mam dotaz, zda nekdo tenhle kram provozuje a funguje to cca den v kuse. (neodpojuje se to)
Vnuceny ovladac, fw 1.77, w10 32b a stale se ztraci komunikace s dv4mini. To i behem provozu.
Ani jako spravcem spusteny sw nefunguje. (posleni verze 20200303)
Nastaveni adresy na "toto pc" nebo primo 127.0.0.1 nepomaha..
Kdyz je ovladaci sw na vrsku (jako aktivni okno) dela to mene casteji. Jak neco zacnu deat na NB a jde app do pozadi tak se to odpoji (ztrati dongl).
Pravdepodobne je chyba v tom US operacnim systemu, ale kde ho posimrat, aby dv4mini fungovalo...
scanning for DV4minis ...
searching DV4mini ...1 on 127.0.0.1
Stick configuration loaded successfully
16:10:22,962 (00004):DV4mini ... received Config from GUI
16:10:22,962 (00000):DMR ... Stop DMR
16:10:22,968 (00006):DV4mini ... set mode: DMR
16:10:23,012 (00044):ADF ... DV4mini Stick Msg: enhanced DMR/DSTAR sync mode
16:10:23,481 (00011):DV4mini ... REF-IP: 80.250.21.206
16:10:23,481 (00000):DV4mini ... C4FM gateway mode = OFF
16:10:23,482 (00001):DV4mini ... C4FM hamnet mode = OFF
16:10:27,930 (04448):DV4mini ... received Config from GUI
16:10:27,945 (00015):DV4mini ... set mode: DMR
16:10:27,990 (00045):ADF ... DV4mini Stick Msg: enhanced DMR/DSTAR sync mode
16:10:28,448 (00458):ADF ... set RX / TX qrg: 438025000 / 438025000
16:10:28,448 (00000):DV4mini ... REF-IP: 80.250.21.206
16:10:28,449 (00001):DV4mini ... C4FM gateway mode = OFF
16:10:28,449 (00000):DV4mini ... C4FM hamnet mode = OFF
16:10:28,450 (00001):DV4mini ... Connect request to DMR 4000
16:10:28,452 (00002):DMR ... Set Reflector:4000
16:10:28,472 (00020):DMR ... MMDVM server connected to MMDVM:4000
connection to 127.0.0.1 lost
16:10:51,958 (00020):DMR ... Stop DMR
16:11:23,977 (00000):DV4mini ... received Config from GUI
16:11:23,977 (00000):DMR ... Stop DMR
16:11:23,992 (00015):DV4mini ... set mode: DMR
16:11:24,055 (00063):ADF ... DV4mini Stick Msg: enhanced DMR/DSTAR sync mode
16:11:24,508 (00453):ADF ... set RX / TX qrg: 438025000 / 438025000
16:11:24,508 (00000):DV4mini ... REF-IP: 80.250.21.206
16:11:24,508 (00000):DV4mini ... C4FM gateway mode = OFF
16:11:24,508 (00000):DV4mini ... C4FM hamnet mode = OFF
16:11:28,953 (04445):DV4mini ... received Config from GUI
16:11:28,968 (00015):DV4mini ... set mode: DMR
16:11:29,015 (00047):ADF ... DV4mini Stick Msg: enhanced DMR/DSTAR sync mode
16:11:29,484 (00469):ADF ... set RX / TX qrg: 438025000 / 438025000
16:11:29,484 (00000):DV4mini ... REF-IP: 80.250.21.206
16:11:29,484 (00000):DV4mini ... C4FM gateway mode = OFF
16:11:29,484 (00000):DV4mini ... C4FM hamnet mode = OFF
16:11:29,484 (00000):DV4mini ... Connect request to DMR 4000
16:11:29,484 (00000):DMR ... Set Reflector:4000
16:11:29,500 (00016):DMR ... MMDVM server connected to MMDVM:4000
Zkusim to jeste povesit na malinu.
DIky za tipy. Martin tec.
OK1MSU
Jméno: OK1MSU-Martin
Re: DV4mini nefunkcni
Post by OK1MSU »
Jo jo pouzivam bezproblemove! Take se mi odpojovala a po trvalem vypnuti BlueTooth v PC mi to prestala delat a je jiz vse Ok. Dost dlouho mi trvalo, nez jsem na takovou blbost prisel, vysledek je 100%.
Users browsing this forum: Ahrefs [Bot] and 14 guests
